Readybear
Jan 06, 2023Aspirant
Can't connect to the Frontview of a Readynas Ultra 4
My Readynas lost a drive a while back so I'm trying to not boot it up too often until I have a replacement drive. The firmware is possibly the latest version and I don't want to check again until I h...
Jan 07, 2023Guru - Experienced User
Readybear wrote:
Different browsers give different errors. Chrome says ERR_CONNECTION_RESET. I'm never able to reach the login page.
Are you running 4.2.x firmware or have you converted the NAS to OS-6?
FWIW, RAIDar should be telling you the firmware. Current versions are
- 4.2.31
- 6.10.8 (if you converted).
Readybear wrote:
On my windows machine on the network page the Readynas is listed as a media device but not as computer so I can browse my files.
If you are using 4.2.x firmware, have you checked that the PC has the SMB 1/CIFS client enabled? Do this by going into "turn windows features on or off".
Does entering \\nas-ip-address in the File Explorer Address bar give you access from Explorer? (using the real NAS IP address of course).
Readybear
Jan 07, 2023Aspirant
Thanks for the reply. Booted it up again (didn't want to because it's missing a drive) and according to Raidar it's running 4.2.31. I had already enabled the SMB 1/CIFS client before (forgot to mention) but it turns out I forgot to reboot because I was doing other stuff on my PC. After rebooting the PC the Readynas does show up as a computer on the network page and I even played a video file.
So the only remaining two problems are that I have to get a new disk and that I'm not able to connect to Frontview. Should I try a USB Boot Recovery already? I don't want to unless it's really necessary.
- StephenBJan 07, 2023Guru - Experienced User
Readybear wrote:
So the only remaining two problems are that I have to get a new disk and that I'm not able to connect to Frontview. Should I try a USB Boot Recovery already? I don't want to unless it's really necessary.I don't think I'd try a USB recovery at this point.
Have you resolved the SSL protocol issue with 4.2.x firmware already? If not, is that one of the frontview errors you are seeing?
