sonic523
Mar 29, 2022Initiate
Can't expand ReadyNAS ISCSI
Hi, I am unable to exapand a share. We are running a ReadyNAS 3138 with 4x 6TB disks in Raid10. Current firmware is 6.10.7. We have 1 volume. Running on Flexraid, We are not using snapshots. ...
- Mar 29, 2022
Not with FlexRaid.
But I think Netgear might have limited the allocation to 90% of the volume size. BTRFS can misbehave badly if it runs out of free space (though in your case there shouldn't be that much of an issue since you are only using the one LUN).
Mar 29, 2022Guru - Experienced User
Not with FlexRaid.
- sonic523Apr 06, 2022Initiate
thank you for your reply. i'll mark your answer as the solution, as you are the only that replied. I'm still waiting for Support but i kinda gave up on them. We will change out the device with one from a reputable brand.
