KARREV
May 11, 2016Follower
Can't find the storage capacity I should have
I bought several month ago a ready Nas and Two DD of 6 TB. Both seem to work fine (I can find ther with a green light on the admin page with the right capacity. But the total capacity of the storag...
BrianL2
May 11, 2016NETGEAR Employee Retired
Hi KARREV,
Welcome to the community!
It is possible that your current RAID configuration is RAID-1 (mirror) that's why your total volume capacity is just half of what you're expecting. If you want to maximize the total capacity of both drives, you need to destroy the volume and build a new volume with Flex-RAID 0 or JBOD. Lastly, can you confirm if the X-RAID button under System -> Volumes is ticked?
Kind regards,
BrianL
NETGEAR Community Team
keikeimok
May 12, 2016Aspirant
Hi, I am using X raid and I have 4X 4TB hard disk installed. Is it normal that I could only see10.9 TB in total?
I was wondering if I would like to expand the total 16 TB to 24 TB, what is the best way to do it?
Thank you very much
Keith
- Retired_MemberMay 12, 2016
You can check NETGEAR's RAID calculator: http://rdconfigurator.netgear.com/raid/index.html
This article may also be of help: http://kb.netgear.com/app/answers/detail/a_id/23135
- keikeimokMay 12, 2016Aspirant
HI
I see, thank you very much. Also I read about from the compatibility list of HD support 8TB per slot. Does that means my RN104 could support up to 32 TB ? I saw from the website saying only support up to 12 TB.
Cheers,
Keith
The spec is 16TB, not 12TB.
https://www.netgear.com/home/products/connected-storage/RN10400.aspx?cid=gwmng#tab-techspecs
I don't know if you'd be able to manage 32TB in a RN104.
If you have money for 4 HDDs of 8TB, maybe you should invest in a more powerful NAS, like RN204 or RN214 ;)
http://www.netgear.com/home/products/connected-storage/RN204.aspx?cid=gwmng#tab-techspecs
http://www.netgear.com/home/products/connected-storage/RN214.aspx?cid=gwmng#tab-techspecs
- Sep 02, 2016Retired_Member
