egoff
Oct 24, 2012Aspirant
Can't get correct replacement part from support
I have a ReadyNAS 3100 under warranty, with a failing power supply. I've had a case open with Netgear support for 25 days. It took about 2 weeks for them to agree the power supply needed to be replace...
beisser1
Oct 25, 2012Tutor
his casenumber is 19548759
according to the system the correct part should have shipped.
must be something with warehouse stock.
lets wait what siigna says.
