karby
Feb 19, 2019Aspirant
Can't get email notifications to work
i'm not very knowledgeable... but have always muddled my way through configuring my NV+ V2... and then forget it for a few years... but
now i'm doing some cleaning and want to add a 3rd disc and f...
karby
Feb 21, 2019Aspirant
Thank you for your reply, and your enormous patience.
After making the corrections you suggested i still got a pop up of "Unable to send test message" and lower one too of "Failed to contact SMTP server"... but i also received an email from Google saying that an app tried to access my account as you predicted.
Since i am a big Google user (via Android devices) i am very relucant to decrease Google security in order to allow ReadyNAS notification e-mails.
In my earlier search for solutions i had already seen a post advising that "it's better to create an "app password" than allowing "less secure app"... but i have no idea how to accomplish that.
alternately, can i use one of my e-mails at the domain name i own or my local ISP to avoid this problem? i am confused by the "Account Provider" tab, since my ISP is not listed and i have no idea how to configure a "Custom" account.
Feb 22, 2019Guru - Experienced User
Just to clarify this - the security risk here is only that the ReadyNAS knows your gmail password. In my opinion that's not a big risk.
https://support.google.com/accounts/answer/185833?hl=en
Most ISPs provide the information needed to configure email. You are looking for the SMTP information.
If you aren't using webmail, you can also look at your email client settings.
