CatDaddy60
Aug 27, 2024Tutor
Can't get to Admin page after firmware update.
Just before I went on a week's leave on Friday, I logged into one of our Netgear ReadyNAS devices to check on something and was told that it required a firmware update. I carried out the update, ...
Aug 27, 2024Guru - Experienced User
CatDaddy60 wrote:
I carried out the update, the NAS rebooted, and I was able to login again. However, there was another update prompt (can't remember what for but it wasn't the usual 'You need a firmware update' dialog) so I let it go ahead and do that.
It's unfortunate that you don't recall what it was telling you, as that action must have triggered the problem.
Are you sure it was an "update prompt", and not something else?
See if RAIDar can give you any useful status:
CatDaddy60
Aug 27, 2024Tutor
Yes, I'm sure it was an update prompt as it appeared to download and install something before it told me that it was rebooting.
I've just posted as image of what RAIDar diagnostics is apparently showing my colleague in the office.
- StephenBAug 27, 2024Guru - Experienced User
I'm not seeing any image
Do you have any apps installed on the NAS?
- CatDaddy60Aug 27, 2024Tutor
StephenB wrote:
CatDaddy60 wrote:I've just posted as image of what RAIDar diagnostics is apparently showing my colleague in the office.
CatDaddy60 wrote:Yes, I'm sure it was an update prompt as it appeared to download and install something before it told me that it was rebooting.
I've attached it to this reply - no apps that I'm aware of beyond any that may have come pre-installed.
