MichalPavlik
Jan 12, 2017Aspirant
Can't manage my ReadyNAS102
Hallo there, I'm sorry if this problem is there solved somewhere, but my english is not so good to find it. If I want to manage my Ready NAS102 from page readycloud.netgear.com (where it was fin...
mdgm-ntgr
Jan 12, 2017NETGEAR Employee Retired
You can do an OS Re-install using the boot menu to reset the admin password.
You can update to 6.6.1 using these instructions: ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
MichalPavlik
Jan 13, 2017Aspirant
Finaly I finded this advice:
2016-12-29 05:40 PM
OK you need to perform a OS Re-install as shown on Page 19 here
This will reset the user login//password to the default values.
These are:
Login: admin
Password: password
It will also change some of your Internet protocol settings to defaults
DO NOT perform a Factory Default as it will delete all of your data
And it helped fix all my problems.
Thank you very much mdgm and bedlam1
