SteveHol
Sep 01, 2021Aspirant
can't reset my Readynas 316 password from boot menu
Hi Hope someone can help. 1) I forgot my admin password 2) password reset doesn't work 3) booted to boot menu - but my front screen is NOT responsive. Doesn't work. So I can't get to the ...
SteveHol
Sep 07, 2021Aspirant
Damn, i was sure hoping I'd have Option A B C by now.
Hope you're not put off by "I forgot my password", the ultimate idiot crap.
Okay, here's the story. This was my brothers NAS and he passed. I'm trying to recover all his family pics for his wife and kids. It's all very sad and I'm not trying to push my sister in law about where the password might be.
Thanks.........
Sep 08, 2021Guru - Experienced User
SteveHol wrote:Hope you're not put off by "I forgot my password"
No, just that there aren't a lot of options when the boot menu doesn't work. Just to make sure you have the right instructions: The boot menu operation is described on pages 81-82 of the hardware manual here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Normally that wouldn't need the NAS admin password. Have you tried simply booting it up, and then accessing the NAS with Windows Explorer? Enter \\nas-ip-address in the address bar (using the IP address you see on the LCD panel after a normal boot). Be careful to use the correct slash (// will open your browser, which isn't want you want).
If you use one of their PCs, any credentials you need for access might be automatically applied (and could be seen using the Windows Credential Manager).
FWIW, there's also a reasonable chance that the NAS admin password is saved in the browser. If you have his browser and PC credentials, you should be able to export his saved passwords.
