jackdellis
May 10, 2023Aspirant
Change Boot Order/Priority ReadyNas
Hello, I'm trying to install Unraid on my ReadyNas instead of ReadyNas OS6, I've found some information online which suggests that I need to change the boot order via bios so that my ReadyNas will bo...
Sandshark
May 10, 2023Sensei
Just like on a PC -- via the BIOS settings at boot.
You are lucky to have a ReadyNAS with a video port. Most don't, which will be a major stumbling block for most owners trying to install an alternate OS.
- jackdellisMay 11, 2023Aspirant
I've connected the RN316 to HDMI, then i've turned it on, this page comes up on the screen which I can login to:
I'm not sure whether this is the right place, i've then entered the username and password and i've been told to try pushing F1, F2 or the DEL key, these don't do anything and I don't think i'm doing this in the correct place.
- jackdellisMay 12, 2023Aspirant
Update: You have to power on the ReadyNAS, right after pressing the power button, start pushing the DEL key on the keyboard, i pretty much did it repeatedly, the device will output the BIOS screen through the HDMI
