jackdellis
May 10, 2023Aspirant
Change Boot Order/Priority ReadyNas
Hello, I'm trying to install Unraid on my ReadyNas instead of ReadyNas OS6, I've found some information online which suggests that I need to change the boot order via bios so that my ReadyNas will bo...
Redlikemethodz
Apr 03, 2025Guide
Does your boot priority reset though after reboot??? Mine is doing this.
- SandsharkApr 04, 2025Sensei
I have read that there is a place in the BIOS to disable the flash, which you have to do in addition to changing the boot order, so it won't revert back to using the flash. But I don't recall what the setting was called and I don't have a similar NAS currently set up to look for it. On units with a DOM for flash, you can simply remove the DOM. But on those with soldered-in flash, you don't have that option.
