jackdellis
May 10, 2023Aspirant
Change Boot Order/Priority ReadyNas
Hello, I'm trying to install Unraid on my ReadyNas instead of ReadyNas OS6, I've found some information online which suggests that I need to change the boot order via bios so that my ReadyNas will bo...
Redlikemethodz
Apr 03, 2025Guide
Does your boot priority reset though after reboot??? Mine is doing this.
Sandshark
Apr 04, 2025Sensei
I have read that there is a place in the BIOS to disable the flash, which you have to do in addition to changing the boot order, so it won't revert back to using the flash. But I don't recall what the setting was called and I don't have a similar NAS currently set up to look for it. On units with a DOM for flash, you can simply remove the DOM. But on those with soldered-in flash, you don't have that option.
