jaholstein
Feb 11, 2018Guide
change Device Name
On my ATT router on the device list - My RN104 shows as IPv4 Address / Name 192.168.1.10 / unknown28c68e353fc8 How can I get it to show IPv4 Address / Name 192.168.1.10 / Read...
- Feb 11, 2018
I think this is really an ATT router question. The NAS is advertising its hostname, but the ATT router isn't using that in it's attached device list.
Many routers will let you manually enter a device name, and will remember that name across reboots, etc - it is generally bound to the mac address of the device.
Feb 11, 2018Guru - Experienced User
jaholstein
Feb 11, 2018Guide
YES that is what I've found on the ATT community board.
The problem is that THIS SPECIFIC router does not allow a substitute name.
Manufacturer ARRIS
Model Number BGW210-700
