Hemppa
Jul 31, 2011Follower
Changing both HDD's at once?
Hello! I bought ReadyNAS Duo few days ago, and put two Samsung F3 1 TB HD103SJ drives in. I didn't notice that Samsung SJ -series isn't in the HDD HCL. So, my question is: Can I change both dri...
fbmachines
Jul 31, 2011Guide
If wiping out all the data on the disks is Ok, then yes (or in this case just starting from scratch again).
Power down the unit and replace both disks. Then follow the procedure to do a factory reset from the boot menu...
http://www.readynas.com/kb/faq/boot/how ... ry_default
