thebigerns
Dec 18, 2018Aspirant
Changing filename Case? ReadyNAS 424
Firmware 6.9.4
I have a share (SMB/AFS) that is used by MacOS (me) and a Windows 7 user. The Win 7 user can access the drive, create and delete content, change file/folder names but in instance...
Sandshark
Dec 18, 2018Sensei
SMB and Windows are not case sensitive. I think he is just getting an odd message not really related to permissions. Windows just assumes that's the problem when the write fails.
thebigerns
Dec 26, 2018Aspirant
Thanks for the reply and suggestion, I am grateful for your time and effort. I know it seems like a small issue, but still frustrating and distracting for collaboration. I will have to try and test this under Windows 10 maybe.
