Dedi
Jul 09, 2019Aspirant
Changing HDD 2x 6TB
Hi there, I tried to change my disks (before 3 TB) and bought two WD Red 6 TB. First I changed disk 2 (take off the old one an put in the new). It seemed to me, that the synchronisation works. It...
- Jul 13, 2019
It works!!!!!
Thank you for your help. It was a hard way to change the disks and without your helf .....:smileysad:
I summarize what I´ve learned:
1. Never ever change a disk if you aren´t VERY SHURE that the synchronisation is ready!
2. Always change the disk, when the NAS is working (hot swapping)!
3. Reboot in case of little errors.
Dedi
Hi Marc,
thank you for your answer. (My english is not very good, so I´m not shure whether I understand you. Ok, let´s try :-)
I got no warnings
RAIDar is a special software, right? I downloaded and extracted ....but what to do now?? No *exe!!??
When I call the NAS in my Browser the system info says "Volume scan failed to tun properly" and (in german) "the paths to the shares can´t be found. This happens when ReadyNAS coundn´t reach the volume".
Does it matter whether the disks are in shaft 1 or 2 (I changed first 2 and than 1)?
Marc_V
Jul 09, 2019NETGEAR Employee Retired
The volume is not available or inactive. Can you install RAIDar and check the status and also try to download the logs.
It does not matter what disk you replace.
Regards
- DediJul 09, 2019Aspirant
MARC
I downloaded RAIDar, extracted the file ... but there is no *.exe. What to do?
- StephenBJul 09, 2019Guru - Experienced User
Dedi wrote:I downloaded RAIDar, extracted the file ... but there is no *.exe. What to do?
What version did you download? What operating system are you using on the PC? Windows?
I work with Windows10; downloaded RAIDiator 5.3.13 and installed it with the dashboard, "firmware update". Probably this was the wrong way; no more shares and no reports :-(
Maybe I´ll do best, repaeting the whole procedure. What do you mean?
.....Installing the one of the old disks (3 TB) and on of the new (6TB)....synchronizing .... and changing the second one.
How can I´m shure that the first synchronizing prozess is completed?
