Dedi
Jul 09, 2019Aspirant
Changing HDD 2x 6TB
Hi there, I tried to change my disks (before 3 TB) and bought two WD Red 6 TB. First I changed disk 2 (take off the old one an put in the new). It seemed to me, that the synchronisation works. It...
- Jul 13, 2019
It works!!!!!
Thank you for your help. It was a hard way to change the disks and without your helf .....:smileysad:
I summarize what I´ve learned:
1. Never ever change a disk if you aren´t VERY SHURE that the synchronisation is ready!
2. Always change the disk, when the NAS is working (hot swapping)!
3. Reboot in case of little errors.
Jul 12, 2019Guru - Experienced User
Dedi wrote:
But I have TWO 6 TB disks in my NAS. 3 TB was the size of the old disks, which I have changed. (Screenshot)
You didn't say you'd completed both syncs. I thought you still had 3 TB + 6 TB.
Try rebooting the NAS, and see if the volume expands. It should do another resync (on the unused space).
Dedi
Jul 13, 2019Aspirant
It works!!!!!
- StephenBJul 13, 2019Guru - Experienced User
Great news. I'm glad I was able to help - normally it's not this difficult. :smileyhappy:
