Kaktus_2016
Jan 17, 2016Aspirant
Cloning problem?
Hi,
I have bought a ReadyNAS Duo v2 (RND2000v2) and a ReadyNAS RN10200. Both NASes have two harddrives and all the four harddrives are identical.
I have downloaded Readynas replicate for the ReadyNAS Duo V2 as it was not installed into it. I have then activated it and activated the ReadyNASremote and ReadyNAS Replicate on both of them, but not the ReadyCloud on the RN10200.
When I log into ReadyNAS' replicate I'm able to see the two NASes, but I'm not able to see the folders on them or create any new one. Therefore I'm not able to create any data or system backup.
My plan is to have the NASes placed on two two different addresses with each connect to the respecitve home network and then have the data cloned, so if one house burns then all the data is also stored at the other house.
Have any of you guys had similars problems with creating folders in replicate ReadyNAS?
Kind regards
Henrik
- mdgm-ntgrNETGEAR Employee Retired
Which firmware is on each unit?
- Kaktus_2016Aspirant
Hi Mdgm,
The ReadyNAS Duo v2 has firmware version 5.3.11 and the ReadyNAS RN10200 has firmware version 6.4.1.
Kind regards
Henrik
Can you send me your logs from each unit (see the Sending Logs link in my sig)?
