chuck2go
Apr 20, 2020Aspirant
Configure APC Powerchute (UPS) on RN214
Re: NAS RN214 Firmware 6.10.3 APC BR1500MS UPS I am attempting to install/configure APC Powerchute auto shutdown s/w on the RN214. It appears that I'll need some instructions to get that...
chuck2go
Apr 21, 2020Aspirant
First, I apologize that I didn't specify that I'm using Windows 10 on associated PC's.
I had assumed that the USB ports on the front of the UPS are just for charging.
I did connect a USB cable between the UPS and the RN214 NAS and rebooted the NAS. However, I did not see any reference to the UPS displayed by the NAS.
Is there a way to find out if the NAS and UPS are communicating? Also, can I configure anything related to the auto-shutdown?
Thanks
Apr 21, 2020Guru - Experienced User
Look on the power tab of the web ui. There's a UPS section there that you can expand (which has some settings).
- SandsharkApr 21, 2020Sensei
The USB ports on the front of the UPS are just for charging. The cable you need to connect to the NAS is the one that came with the UPS and plugs in the back. Why APC does not use a standard USB B jack on te rear, I have no idea.
I assume you connected a front USB port on the UPS to a USB port on the NAS with a USB A male to USB A male cable, which is not supposed to exist IAW the USB spec. Hopefully, those who ignore the spec and make them anyway know enough to not connect the 5V power line and you have done no damage to either the UPS or NAS.
