Urban-Magilla
Sep 18, 2023Follower
Confusing ReadyNAS Folder Navigation
I have a ReadyNAS 422 which shows up in two places in Windows File Explorer. On my Win 11 machine, it's in This PC and also in the Network list of devices. On an older Win 10, it's in My Computer a...
- Sep 18, 2023
One entry is for the DLNA server built into the NAS, the other is for file access to the shares.
If you don't use DLNA to play your media (for instance on a smart tv), then disable the service in system->settings->services.
Sep 18, 2023Guru - Experienced User
