Juler
Mar 04, 2017Aspirant
Connect Riello ups with netman 204 to ReadyNAS 2120
I wand to connect the riello UPS with Netman 204 to the readynas.
But the manufacture ist not listet.
if i use Socomec, the connection is green.
With this attitude, I`m not sure if this is correct.
- JennCNETGEAR Employee Retired
Hello Juler,
Perhaps you would like to check at ReadyNAS Hardware Compatibility board. I will move your post to that board too.
Welcome to the community!
- FramerVNETGEAR Employee Retired
Hi Juler,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
