BrennanB
Mar 16, 2013Aspirant
Connecting 2 x NV+ to 1 x UPS
I have 2 x NV+ v1 and want to connect them both to the same UPS but my concern is that only one of the NV+ can connect via USB to the UPS. SO what I'm wondering is how to set it up so both NAS will wo...
rnas_newbie
there are a links on a few posts eleswhere on the forum, but I always revert to the following link;
http://home.bott.ca/webserver/?p=466 (also shows how to protect additional pc's)
it has a screenshot for the 1st unit connected via USB, the 2nd unit is fairly straight forward.
the question using this method though has to be- is your switch that would carry the signal...also protected via a UPS?
if not - there's many inexpensive ways to overcome the situation (customising a trailing lead with an IEC connector etc)
