BrennanB
Mar 16, 2013Aspirant
Connecting 2 x NV+ to 1 x UPS
I have 2 x NV+ v1 and want to connect them both to the same UPS but my concern is that only one of the NV+ can connect via USB to the UPS. SO what I'm wondering is how to set it up so both NAS will wo...
rnas_newbie
Mar 19, 2013Aspirant
BrennanB wrote: Very good point about the switch! I've put the switch on UPS power, I've connected all Infrant to a UPS and then have 2 of them pointing at the one Infrant with a USb plugged into the UPS.
thanks for the feedback that you've successfully set it up.
another trick to test all is well...is to power one (or all) of your remote Readynas's directly via normal power sockets, then turn off the power to the UPS. eventually the switch will drain the power and invoke the critical alarm signal, if all is well, the readynas's should shut down (even though they are technically on mains power!)
to speed this up you could tell your master readynas to switch off at 90% ups power.
