BrennanB
Mar 16, 2013Aspirant
Connecting 2 x NV+ to 1 x UPS
I have 2 x NV+ v1 and want to connect them both to the same UPS but my concern is that only one of the NV+ can connect via USB to the UPS. SO what I'm wondering is how to set it up so both NAS will wo...
Mar 19, 2013Guru - Experienced User
Ideally you'd test the shutdown with the actual settings you plan to use.
The best way to speed it up is to plug in a lamp [or some other suitable load) to drain the battery on the UPS at a more normal pace. Switches don't take much power, so could take a very long time if that is the only load.
