pksparks
Jan 06, 2010Aspirant
connecting apc cs-650 to readynas duo
hi, after finbding my house in the dark, because of a powerdown, and also a nas down, i want to buy a apc ups. but while i am looking at the site of apc, there are a lot of cables optional for connct...
Mar 20, 2012Guru - Experienced User
Yes that is what I am also trying to say...
mdgm wrote: Well with my Duo v2, the external power brick has a detachable cable connected to it. If there is a detachable cable with a wall plug on it ideally replace this cable to the wall socket with a cable that has the appropriate connector on the end. Otherwise you'll have to find an adapter for the plug that goes into the wall socket.
Looking at his posts, I suspect Siege is thinking he connects the v2 directly to the UPS (with no brick).
