mountaindude
Apr 30, 2013Tutor
Connecting ReadyNAS Ultra to remote NUT server
I am trying to get my 2-disk ReadyNAS Ultra (x86) to understand it should connect to a remote UPS NUT server. The ReadyNAS can do this already, as long as there is another ReadyNAS it should connect...
mdgm-ntgr
Apr 30, 2013NETGEAR Employee Retired
Well did you try setting that username and password as the credentials on the remote NUT server. The ReadyNAS probably automatically attempts to use those credentials to connect to the NUT server
