Gord_in_Toronto
Dec 03, 2018Aspirant
Connecting RN212 to Cyber Power CP850AVRLCD UPS
Can I just plug it in? I don't need any management features from the NAS device.
As Sandshark suggests, it's best to connect the USB port in the UPS to one of the NAS USB ports. The NAS will automatically monitor the UPS, and do a clean shutdown when the battery drains. There is no need to install any software in the NAS, everything needed is built-in.
- SandsharkSensei
Of course you can. But why would you not want management features from the NAS? Should a power outage be long enough that the UPS is going to shut down, you really want the NAS to shut down gracefully.
- Gord_in_TorontoAspirant
Thanks.
I'm currently using the Cyber Power POWERPANEL Personal software to shutdown my PC via the USB connection. I see no obvious way to gracefully shutown both the PC and the NAS..
Gord
In my experience, it's more important to shut down the NAS cleanly - so if you need to choose, I'd connect the NAS to the USB port.
The NAS uses the Network UPS tools. There is a beta package available for Windows here: https://networkupstools.org/download.html#_binary_packages
It is possible to monitor the CyberPower status over the network (through the NAS) - but doing that also requires that any equipment on the network path (switch or router) be protected by the same UPS.
