mswain94
Jan 02, 2018Follower
Connecting to the NAS ready from another branch
Hi There I was wondering if anyone could help, we have recently opened a new site and i would like to connect to the NAS in our main branch, ideally i want to map them on the computers as a netwo...
Marc_V
Jan 07, 2018NETGEAR Employee Retired
Hi mswain94
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- SandsharkJan 07, 2018Sensei
I agree with you that ReadyCloud is not the way to go in a business environment. The fact that your ReadyCloud user and your local user are diofferent users is the number one reason, but there are others. A VPN is the way to go. There are many ways to implement that. You can do it in your router or in the NAS. I personally like ZeroTier, as it establishes a "parallel connection". The standard IP is still there, and then there is the private ZeroTier port. You have to install ZeroTier on each PC (or phone) that needs to access the NAS, but then you just use the ZeroTier address anywhere you would normally use the standard IP address. It even works NAS-to-NAS. More details here: ZeroTier-and-the-ReadyNAS.
You can find a ReadyNAS specific version here: NAStools/zerotierone. It's a bit old, but still works. It has an advantage of a GUI. Alternately, you can do a standard Linux install via SSH, which has only a command line interface.
