Omega_up
Feb 17, 2020Aspirant
Connection keeps dropping
Morning all
I have just perched a readymas 214 and it keeps dropping network connection. I keep getting this message “ The following device lost communication with the NETGEAR Insight cloud service at approximately “ then after a min it reconnects but it makes streaming virtually impossible can anyone help!
Thanks
Thanks
Omega_up wrote:
Morning all
ThanksDrops in the Insight connection aren't that unusual, and the only real way to actually prevent them is to turn off Insight (which has limited value for ReadyNAS anyway).
But streaming isn't going through Insight, so if that is also being disrupted, then something else might be going on. If this is a new purchase (within 30 days) you should probably use your phone support.
What are you using for streaming? DLNA, Plex, something else?
Is the streaming local to your home network, or are you streaming over the internet?
Have you downloaded the log zip file from the web UI and looked for network and disk/btrfs errors?
- Omega_upAspirantI am steaming from nas to WDTV LIVE media box and to my pcs and laptop on my home network. I have not as yet looked at the log zip file for errors I thought it might be something to do with the network adapters on the nas maybe not setup correctly.
