machefi
Nov 01, 2016Aspirant
Connection problems after update 6.6.0
After updating to version 6.6.0 adminiastratora page loads without problem and works even faster. I do not know whether an update is causing the problem. However, on a local network storage is no lon...
Nov 01, 2016Guru - Experienced User
machefi wrote:
They are set to SMB and DLNA. I checked the 'System> Settings> Services', there SMB indicator is inactive. I can not change its settings active.
I'd contact support on this, stressing that the upgrade to 6.6.0 caused this issue.
- machefiNov 09, 2016Aspirant
Thanks for the advice. I could not find email support, telephone is paid - my English is a little weak. It remains to me to wait, and once again review the FAQ. Maybe someone remedy or another update to change it ...
Have a nice day.- StephenBNov 09, 2016Guru - Experienced User
Did you look in the Windows credentials manager of your PC?
The idea is to remove any credentials there for the NAS, and to create new ones using a username/password for an account on the NAS. The NAS admin account can be used if you have no user accounts there.
I checked the credential manager in PC with Windows 7. There are no entries. In the TV rather I not find. With the creation of the credentials of the IP, admin / password - still without effect.
The administrator page 'Shares> Shares' change protocols folders possible for SMB and DLAN - no effect.
Changes in the 'Network>Links' on Statick / Using DHCP - without effect.
By the administrator page I can create folders, copy files to them. But I can not download it.
Login to admin page affected by the RAIDar successful. The 'Browse' or 'View' in RAIDar opens only Windows Explorer on the 'My Documents' (PC folder), no storage.
I can call the device with IP on the local network, but open only the administrator page (in IE, FF or Chrome), no storage.
The device on the network seen as a multimedia device, but it is not possible to open the library device.
