machefi
Nov 01, 2016Aspirant
Connection problems after update 6.6.0
After updating to version 6.6.0 adminiastratora page loads without problem and works even faster. I do not know whether an update is causing the problem. However, on a local network storage is no lon...
Nov 02, 2016Guru - Experienced User
meinokramer wrote:
hi ,i cant reach the nas with windows explorer after update to 6.6.0.
dlna works well,and the main site with http works also.
the error calls ...''the nas has a wrong name ,check the networks on problems.''
grtz meino
Did you try accessing it by both its IP address and its hostname?
Also, look in settings->services and check that SMB is turned on. Also check that SMB is still enabled for each share.
meinokramer
Nov 02, 2016Aspirant
yes ,,both done.
i can see my nas in windows network but when i will access the nas the error appears.
''controleer spelling van de naam ,er is anders een probleem met het netwerk''(dutch)
check the spell of the name,otherwise there 's a problem with the network
grtz meino
- meinokramerNov 02, 2016Aspirant
setting smb is also ''on''
- StephenBNov 02, 2016Guru - Experienced User
What happens if you run CMD and enter
net use * /delete
net use t: \\KRAMERNAS\data /user:admin nas-admin-password
Substitute the real admin password, and be very careful on the typing (particularly the slash directions).
What it should do is mount the NAS data volume as drive letter t.
BTW, if you use flexraid you'll need to use your volume name instead of "data".
