brianf1
Apr 06, 2013Aspirant
Considering upgrading to a later model... Suggestions Please
HI. I currently have an X6 Rev. A. It has worked great for many years, and still does. I am thinking of upgrading to a newer model. I do not have a huge requirement list Requirements: Prima...
Apr 06, 2013Guru - Experienced User
The RN104 is supposed to stream to Apple-TV, though at present I have no way to test it. I did test the server (in an RN102) with iTunes-11. Note that there is no Linux iTunes server that supports the iTunes home sharing feature.
The 314 would also have Plex built-in. I'd go with the 314 if you can afford it.
What I wouldn't do is buy an NV+ v2 at this point. If you are ok with one the older models, look at the ultra-4 and pro-4. They also have the iTunes server, and Plex is available as an add-on. The UI is similar to what you are used to already, and the performance is better than the v2 and the x6 you have now.
