wildfire23
Dec 01, 2021Follower
Constant bay failure after power down
Firmware 6.10.6
Harddrive: 4x Western Digital 3TB Red Plus NAS HDD
RAID 5
Im currently runing a Ready NAS with x4 3TB drives. Everytime I "Shutdown" my ReadyNAS the 4th bay consistantly losses connection and has to resync. If I "Restart" the NAS this does not appear to be an issue. I previously had x4 500GB Seagate Barracuda's and had the same issue. Is this normal? Is there something I can do to stop it?
Thanks
It's not normal. Maybe try running the disk test from the settings wheel (volume tab). It will take some hours to finish.
- ShipAspirant
RN 314 with 4x 3TB WD Red under xraid (raid 5)
I've just had similar issues to what you are describing in bay 4 and put it down to a disk failure. I've replaced that disk and another with 2x Seagate Ironwolf Pro 8TB and all running well again. So I would think you've got a disk failure.
