lightsabre
Mar 05, 2022Guide
"Control Panel" Access
ReadyNAS Ultra 4 Plus Firmware 4.2.31 Hello. I tried to log in to this NAS and it would not accept my password. Repeated attempts failed. I finally noticed the pop-up box was saying "Con...
- Mar 05, 2022
lightsabre wrote:
It still will not authorize with the default username and password of admin and password.
The default password for a NAS running 4.2.x firmware is netgear1, not password.
However, if you have converted your Ultra Plus to run OS 6 firmware, then the default password would be password.
lightsabre wrote:how do I access the regular UI?
https://192.168.1.137/admin
But if you are running 4.2.x firmware, you will run into another issue - the older systems use TLS 1.0, and the browsers have recently deprecated that (and require TLS 1.2). There is more information on this here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
Note you can still use internet explorer to access web ui. Other options are in the link above.
Mar 05, 2022Guru - Experienced User
