noadvertise
May 21, 2013Tutor
Cooling systems that fit RNDP600E?
Hey all, I've been reading the CPU upgrade topics and want to give my pro pioneer its maximum boost with a quad core. This will require new cooling so far I've read. I am understanding cooling soluti...
fifer55
May 22, 2013Apprentice
As promised, the stock heat sink + the Noctua 25mm height fan is ~ 50mm.
Here is the proof:
Here is the underside of the heat sink:
Note that I measured from the copper plate to the top of the Noctua fan.
The Gelid will NOT fit as at ~50mm, it is already a VERY snug fit. I noticed the Ultra 6 Plus has maybe 1-2mm more, but even then, it is nowhere the needed 59mm of the Gelid.
Also, the RAM is right next to the heat sink. Also there is some type of passive cooling, which I am pretty sure the dimension of the GELID:
Heat Sink with Fan Dimensions (mm): 131 (l) x 123 (w) x 59 (h)
Will not fit. Too high and wide/long.
Here is the proof:
