rajamani_v's avatar
rajamani_v
Copying data from ReadyNAS104 to Seagate Innov8
Hi there,   I am using RN104 with the latest OS.  Have close to 7TB of data, which I am planning to back-up to Seagate Innov8(USB3.1 Gen 2) hard drive. Is there any way to connect the Seagate to ...
  • StephenB's avatar
    Jul 26, 2018
    rajamani_v wrote:
    I tried that as well, but the problem is Innov8 cannot get enough power from the ReadyNAS. Hence, it is not recognised in ReadyNAS.
    You basically have two options.
    One is to find a charger that can act as a power injector (passing through your data connection to the NAS).
    The other is to connect the disk to a PC, and to the backup over the network.
    The second option is probably easiest.
ProSupport for Business
