rajamani_v's avatar
rajamani_v
Copying data from ReadyNAS104 to Seagate Innov8
Hi there,
I am using RN104 with the latest OS.  Have close to 7TB of data, which I am planning to back-up to Seagate Innov8(USB3.1 Gen 2) hard drive. Is there any way to connect the Seagate to ReadyNAS. Or is there a better way to copy the data from RN104 to Seagate Innov8 without much of a manual intervention.
TIA.
  • StephenB's avatar
    Jul 26, 2018
    rajamani_v wrote:
    I tried that as well, but the problem is Innov8 cannot get enough power from the ReadyNAS. Hence, it is not recognised in ReadyNAS.
    You basically have two options.
    One is to find a charger that can act as a power injector (passing through your data connection to the NAS).
    The other is to connect the disk to a PC, and to the backup over the network.
    The second option is probably easiest.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi rajamani_v
    Welcome to the Community!
    You can connect your Seagate Innov8 to the USB 3.0 port of your RN104, unfortunately you will not be able to use the Type-C USB, an adapter will be needed (USB Type C femaile to USB 3.0 male)
    You can then follow the guide on this link on transferring/backing up files from your ReadyNAS to USB Disk.
    Make sure you have enough space on your USB disk so all data will be backed up.
    Hope this helps!
    Regards
    • rajamani_v's avatar
      rajamani_v
      Hi Marc,
      Thanks for your response.
      Regards
      Raja
      • StephenB's avatar
ProSupport for Business
