Ezechias
Jul 06, 2016Aspirant
Corrupt root and cannot setup
Am looking for help to start my NAS again. I am in the stage where I already did a hard factory reset, with the pin at the back. Even that, when I boot, I get "corrupt root" message on RAIDar. Follow...
- Aug 24, 2016
That disk is already partitioned so as a precaution we gave the corrupt root error rather than blindly formatting it. Some users are unaware that the NAS needs to wipe the disks.
A factory default (wipes all data, settings, everything) or hooking the disk back up to a PC and deleting the partitions off it would have resolved this.Seeing that you didn't have any data on the disk I just wiped the partition table off the disk and rebooted the NAS. It should do a brief check of the hard disk, enter a 10 minute countdown and if you haven't chosen the RAID mode using RAIDar (or unplugged the power to abort) by then proceed to wipe the disk, partition it, setup the RAID, install the OS etc.
Ezechias
Hi Stephen,
I already did all that with two seagate disk. I even bought a new disk, this time a Western Digital, and no luck. Now, am testing with an SSD Kingston, still not working. If I put it on remote support mode, can you access and just set everything to factory default ? Once, it was accessed to activate TEAMING. Though it was working well for 2 years, it suddenly failed on a reboot, with no apparent external factors (no disk or config change). Cooling fan is working well.
Jul 06, 2016Guru - Experienced User
Sorry, I don't work for Netgear so I can't do that.
The warranty is 3 years on the ultra, so you should check on the warranty status right away.
- EzechiasAug 23, 2016Aspirant
I was able to telnet in under Tech Mode. From there, I have no idea what to do.
# ls
1 4 7 crypto mounts
10 411 719 devices mpt
11 476 720 diskstats net
12 478 726 dma pagetypeinfo
13 494 728 driver partitions
14 510 729 execdomains scsi
15 527 736 filesystems self
16 577 760 fs slabinfo
166 6 765 interrupts softirqs
168 603 766 iomem stat
17 606 782 ioports swaps
170 609 784 irq sys
171 612 786 kallsyms sysvipc
172 615 8 key-users timer_list
173 616 9 kmsg tty
2 623 acpi loadavg uptime
267 686 buddyinfo locks version
274 689 bus mdstat vmallocinfo
3 690 cgroups meminfo vmstat
372 691 cmdline misc zoneinfo
373 694 cpuinfo modules
# cat version
Linux version 2.6.37.6.RNx86_64.2.4 (jmaggard@calzone) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Thu May 28 16:29:46 PDT 2015
Are there some commands that I can type in to get things back up. The NAS is just sitting on my desk doing nothing, and it's brand new (from a warranty exchange).
- mdgm-ntgrAug 24, 2016NETGEAR Employee Retired
The firmware on the flash was corrupt. This is now fixed.
- EzechiasAug 24, 2016Aspirant
Hi, I rebooted the NAS and inserted a blank HDD. I still get the corrupt root message from raidar.
Screenshot: https://www.dropbox.com/s/cww4kl03kxvszjw/Screenshot%202016-08-24%2021.37.36.png?dl=0
I have again set it to tech mode with same code I gave you earlier. I will leave it overnight if you would like to access.
Thanks again for the help.
