johan_munoz
Nov 29, 2016Aspirant
Corrupt Root ReadyNAS Duo V2 WITH DATA ON IT
Hi. i tried to find the answer i the forums. I have "corrupt root" on my readynasduov2 AND i have data on it and i would like to access to them, Is it possible for me to do something? i did a OS ...
Nov 29, 2016Guru - Experienced User
One option is to contact Netgear support (via my.netgear.com) - ask about "per incident" support. You don't want the "gearhead" stuff. Depending on what is wrong, you might need data recovery (which is expensive).
If you want to try to recover data yourself, it would be helpful to verify the model - many v1 owners mistakenly believe they have a v2 (the labels are confusing). Can you read this guide, and then confirm which NAS you have? http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
It would also be helpful to know the disk configuration that you have - default XRAID (if so, 1 disk or two?) or flexraid (what disks and what raid mode).
- johan_munozNov 29, 2016Aspirant
I did contact them and they told me to first try find help here.
i have: rnd2000v2 ARM processor.
i did have a support time age for another issue and they told me the model was as above.
So what can i do?
BTW, thank you
- mdgm-ntgrNov 29, 2016NETGEAR Employee Retired
It is a v2 with an expired warranty.
One possibility would be a full 4GB root volume, there are others.
Since you have irreplaceable photos on the NAS that are not stored on any other device you may wish to purchase a support contract.
tell me more about how i can do it myself.
