HeFFe
Jul 16, 2019Guide
Corrupt root ReadyNAS Ultra 2
Corrupt root ReadyNAS Ultra 2 I have Tried to factory reset the NAS via boot meny and OS reinstall and Format the disk in windows still same problem corrupt root.
- Jul 17, 2019
If the disks are blank, then the Ultra should be doing a factory install - partitioning them, etc.
Perhaps try zeroing one of the disks again with Seatools, and then power up the Ultra with that disk in slot 1 (leaving slot 2 empty). If that works, then hot-insert disk 2.
HeFFe
Jul 16, 2019Guide
T
