HeFFe
Jul 16, 2019Guide
Corrupt root ReadyNAS Ultra 2
Corrupt root ReadyNAS Ultra 2 I have Tried to factory reset the NAS via boot meny and OS reinstall and Format the disk in windows still same problem corrupt root.
- Jul 17, 2019
If the disks are blank, then the Ultra should be doing a factory install - partitioning them, etc.
Perhaps try zeroing one of the disks again with Seatools, and then power up the Ultra with that disk in slot 1 (leaving slot 2 empty). If that works, then hot-insert disk 2.
HeFFe
Jul 17, 2019Guide
Boot system diskless gives me " No disk" status
Seatools dosent report any problems with the disks
Jul 17, 2019Guru - Experienced User
- HeFFeJul 17, 2019Guide
Wow It worked Thanks Stephen!! I Did zeroing one disk with Seatools usb boot, and started the Ultra with only one disk in slot 1 and after wizard inserted disk 2.
