armandckj
Mar 31, 2010Aspirant
Corsair VS1GSDS400/EU 1GB in Duo
Hi, 1GB, DDR1, 400MHz, PC3200, 16 chip works fine. 2 memory checks ran fine in just under 1.5 hours. Armand
armandckj
Hmm,
Maybe to happy to soon.
The 2 memory test went fine.
Placed the duo online and checked the DLNA server om my tv. It worked fine.
One hour later i logged in from the iMac and after 20 minutes i lost the connection to the Duo disks.
On the Duo the network cable was attached and showing 2 green lights (active and 100Mbps). On the front the blue power light was steady, both green disk lights were steady and occassionally the activity green light went on.
I plugged the network cable from the Duo to another socket in the Router. Still no Duo disks.
Ping-ing to the Duo had no success. 'findsmb' found nothing. Router did work fopr internet access.
Performed a shut down by pressing 5 seconds on the power button. Started up by pressing the power button again.
Everything works. The logs mention a shutdown and a system up. No Errors at all.
Any clueas as to the cause?
Armand
Armand
