armandckj
Mar 31, 2010Aspirant
Corsair VS1GSDS400/EU 1GB in Duo
Hi, 1GB, DDR1, 400MHz, PC3200, 16 chip works fine. 2 memory checks ran fine in just under 1.5 hours. Armand
jpmmuc
Jan 11, 2011Aspirant
armandckj wrote: Hi,
Armand
The same here, because it was not clear if the memory module is ok, I run the memory check 4 times, all ok.
The System is now running fine for 4 days which much load (squeezebox server music library scanns and robocopy). With the 256 MB RAM I had problems, top showed 250 MB in use and 210 MB in swap, the system was very slow with squeezebox server 7.5.2.
System: ReadyNAS Duo
Memory: Corsair Value Select 1 GB, VS1GSDS400/EU DDR1 400MHz PC3200 CL3
(ReadyNAS needs only 300 MHz so CL 2.5 at 300 MHz seems to function)
Startpage shows:
Firmware: RAIDiator 4.1.7 [1.00a043]
Speicher: 1024 MB [2.5-3-3-7]
Greets,
Jpmmuc.
