armandckj
Mar 31, 2010Aspirant
Corsair VS1GSDS400/EU 1GB in Duo
Hi, 1GB, DDR1, 400MHz, PC3200, 16 chip works fine. 2 memory checks ran fine in just under 1.5 hours. Armand
paulb1257
Jan 27, 2011Aspirant
PapaBear wrote: I would hazard a guess that it is memory related. Two things:
1. I do not see the Corsair VS1GSDS400 on the compatibility listing for the NV/NV+/Duo as of 8/1/2010.
2. Looking at the memory specs on Newegg, it is listed as CL3. There have been other posts stating that the CL must be 2.5 in order for it the memory to work.
Hello all,
I just took a look under the hood of my RND2000v2 and it has a stick of Apacer 256MB SOD PC3200 CL3 installed as standard.
