armandckj
Mar 31, 2010Aspirant
Corsair VS1GSDS400/EU 1GB in Duo
Hi, 1GB, DDR1, 400MHz, PC3200, 16 chip works fine. 2 memory checks ran fine in just under 1.5 hours. Armand
gibxxi
Feb 07, 2011Guide
ahpsi wrote: +1 on the Apacer; 256mb SOD PC3200 CL3 P/N 76.8338G.A07.
If memory serves, the Duo does not actually run the memory at PC3200 speed, and so the specs on the label do not nessecarily apply.
From what I can gather the Duo runs at PC2700, CAS level 2.5. Any half decent PC3200 memory (DDR400 / CAS 3) will likely run at the lower speed at the improved timing of CAS 2.5.
So if Buying PC3200 memory, just ensure that it will run at PC2700 at CAS 2.5 in ADDITION to running at it's rated speed.
I used a generic Crucial SODIMM with those very timings at had no issues.
