loonsailor
Dec 14, 2013Aspirant
Crucial 1GB works in my NV+ v1
I just installed a Crucial CT12864X335 in my NV+ v1 after the previous memory failed. Passed the memory test three times, and seems to work fine. Full description, from Amazon, is Crucial Technology...
yawood
Oct 11, 2014Aspirant
Update on the memory for an NV+
Based on the advice in this thread I purchased two 1 Gb Crucial SODIMMs for my two NV+ units. I received them the other day and have now installed both. I ran the memory test three times for each installation with no problems, so I can report that this module certainly works in the NV+ and that I have tested it 6 times. The units are up and running perfectly (I can't say that I notice a huge difference though they do seem a little faster to boot). I was concerned at first because the modules I received did not match the photos on the order page in that the originals (and the order photos) seem to be single sided (chips on only one side) whereas the units I received had chips on both sides but they fitted without a problem and have worked without any worries.
Here are pictures of the original (256 Mb) memory modules:
Here are pictures of the replacement modules:
And the packaging:
And the packaging:
