knutal's avatar
knutal
D-Link DGS-1008D (8-Port Gigabit Switch)
According to the official hardware compatibility list this is incompatible. I have been running this for a week with my ReadyNAS Duo now, and no errors, no problems. Works like a charm.
Perhaps one of the RAIDiator updates made after 2006 when the entry was made has solved the problem?
  • I confirm : this switch works well with XP 32 and with W7 64.
    I encountered no problem since August 2009.
  • I used D-Link DGS-1008D for 3 weeks combined with the MultimediaPlayer Popcornhour A110 and i always had problems with streaming HD Videos.
    Now i replaced D-Link DGS-1008D against an older 100 MB switch and my problems are fixed.
    So, I definetly had problems with this switch.
  • Problems occur with Jumbo Frames. 3 seconds full speed, after that it drops to 2,3 MB/s
  • I have the D-Link DGS-1016D which I believe is the 16 port version of the DGS-1008D, but have not yet enacted jumbo frames. We are noticing loss of the mapped drive connection, but can remount with a double click. I may exchange it under OfficeDepot's 30 day policy. They were out of the HP ProCurve 16 ports when I placed my order.
  • Follow up on jumbo frames, we tried it on the DGS-1016D and it slowed down the system. Have had it in the network since March. Seems to be holding.
  • I had a lot of problems with the 5-port version of this switch (DGS-1005D). Dropouts of shares for a few seconds about every minute or so...
    This was in combination with the DI-624 router.
    Now I removed this switch from the path (so now only the DI-624 router is used), and everything works like a charm now.
ProSupport for Business
