alex-aaa
Mar 23, 2025Follower
Datenwiederherstellung von ReadyNAS Duo
Hallo liebe Community, ich wende mich an euch, da ich seit einiger Zeit nicht mehr auf meine ReadyNAS Duo und die darauf gespeicherten Daten zugreifen kann. Die 2 Festplatten, die sich in der Rea...
Sandshark
Mar 23, 2025Sensei
You are going to have to give a lot more detail on what happens when you try to access it, including any error messages you get, and what changes you may have made in your network or PC since you last had access (new PC, new router, etc.). The Duo uses SMB1, which is depreciated in Windows and has to be enabled (for your mapped drive access), and TLS v1 (for web access), which is blocked by most browsers and some security software.
Have you run RAIDar to see the status of the NAS.
While there are recovery methods, getting you access back to the NAS is best, and that may still be possible.
