Chris_S
Mar 28, 2012Aspirant
Dead Disk.. but not really
Does anybody have the same problem? So far this has happened twice to me: brand new Ultra6. I get the message that Disk1 (also brand new, no SMART errors etc) is dead (out of 4 disks with dual redu...
ReadySECURE
Apr 02, 2012Apprentice
Do you recall what your case number with NETGEAR was?
If you do, please update the title with it.
Those are completely compatible drives with the ReadyNAS Ultra 6.
Have you experienced any of the same issues since support has accessed the unit?
Have you found any indicators of ATA errors or reallocated sectors in the logs?
Have you found any indicators of I/O errors in the logs?
