Chris_S
Mar 28, 2012Aspirant
Dead Disk.. but not really
Does anybody have the same problem? So far this has happened twice to me: brand new Ultra6. I get the message that Disk1 (also brand new, no SMART errors etc) is dead (out of 4 disks with dual redu...
evan2
Apr 11, 2012NETGEAR Expert
Hi Chris_S,
1. Don't use the HDD which has ATA errors,
2. when insert a new disk, ReadyNAS will do disk testing firstly, if it is fail, system won't do resync.
3. Replace a HDD, then cold boot ReadyNAS, system doesn't do sync if the HDD have other system partitions, it prevent user insert a wrong HDD and protect data in it, it can sync if there is not partitions on the HDD.
so you had better hot replace the HDD when system is on.
