IanW
Jun 29, 2020Tutor
Dead Drive
Question: I had a 'data degraded' message on my RN314, and the log said disk 2 was failing. I've replaced that, and it seemed to successfully resync, which was great news!
However, Disk 1 status has now changed to FAILED, and is now DEAD.
Ouch!
If I now replace Disk 1, should it resync again, and all will be OK?!
Thanks for any help out there.
Ian
Can you download the log zip file, and look in mdstat.log? Perhaps copy/paste it into a reply on this post.
- IanWTutor
Here is the log file...
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid1 sda2[0] sdc2[2] sdb2[1]
523264 blocks super 1.2 [3/3] [UUU]
md0 : active raid1 sda1[0] sdb1[2] sdc1[3]
4190208 blocks super 1.2 [3/3] [UUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Mon Jan 12 12:23:29 2015
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 3
Total Devices : 3
Persistence : Superblock is persistentUpdate Time : Tue Jun 30 07:23:55 2020
State : clean
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0Consistency Policy : unknown
Name : 43f60e1a:0 (local to host 43f60e1a)
UUID : e6ffb814:0eeedf9f:d2475f08:d553a116
Events : 119130Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
3 8 33 1 active sync /dev/sdc1
2 8 17 2 active sync /dev/sdb1
/dev/md/1:
Version : 1.2
Creation Time : Mon Jun 29 08:27:19 2020
Raid Level : raid1
Array Size : 523264 (511.00 MiB 535.82 MB)
Used Dev Size : 523264 (511.00 MiB 535.82 MB)
Raid Devices : 3
Total Devices : 3
Persistence : Superblock is persistentUpdate Time : Mon Jun 29 16:47:20 2020
State : clean
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Name : 43f60e1a:1 (local to host 43f60e1a)
UUID : e86619c4:2440f1e3:80674a15:22fbce07
Events : 19Number Major Minor RaidDevice State
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
2 8 34 2 active sync /dev/sdc2- StephenBGuru - Experienced User
Thx. Unfortunately mdstat.log isn't showing the RAID volume at all. But it is showing good status for both the OS partition and the swap partition.
Paid Netgear support (my.netgear.com) is the best path, as this is hard to troubleshoot and I don't know of any good guide. You can try to get per-incident support - but you'll need help from the mods ( JohnCM_S or Marc_V ) to get that. Don't get gearhead support, it doesn't cover what is needed.
